problems to look for in used C32?
Old Apr 21, 2004 | 09:44 AM
IS1's Avatar
IS1
02 C32
What common problems should one look for in a low mileage used 02-03 C32? Are there certain recalls that should have been done?
Old Apr 21, 2004 | 10:27 AM
s4iscool's Avatar
non really, just drive the car...run it through its paces...a confident owner should do this for you or let you do it, if you seem like a serious buyer.
Old Apr 21, 2004 | 11:35 AM
sxgt's Avatar
This has been my expierence for two weeks on my used C32:
1. Air Pump issues - not sure if you can check for it, but be aware of it. Causes CEL.
2. Squeaking bushings on Sway Bars
3. Check Power Steering for leaks, finding the fluid is difficult since it is MB fluid compatible only.
4. 2002 transmission shift concerns. Can update software or live with it. Mine does it, but not a big concern to me.
5. SOS Malfunction - not a malfunction if the service is not active. MB will tell you it cannot be turned off. There are posts here that give you possibilities. I have not pursued it.
These are the things I have found that I think you might run into based on my short expierence.
