Traction problems, what should I do?
(1) ease into the throttle and live with it
(2) wavetrac limited slip?
(3) 18" wheels and tires? I like the OEM 17" wheel set up for their lightness. If I go for 18" they will be heavier and ultimately slower but maybe faster off the line.
Please let me know your thoughts. Thanks in advance.
These cars are geared steeply with that low first gear. You're at the point where you have to learn to drive the car. After you start making a little power, throttle modulation is just as important as knowing how to stay on the driving line.
Just kidding, but it is true. I'm moving to sea level again soon and can't wait to have your problem once more.
I would get a 255 width rear in a sticky tire. The Mich PSS are pretty good for stick, can't understand why they break loose.
had my c32 for 12 years man and nearly same mods as you and same tires.... it wants to just spin like crazy unless you know how to play with the pedal to avoid spin which is an art. Starting in 2nd gear can help. from a stop mine will spin the tires from 1'st to 3rd gear up to about 60+ actually and thats with Pilot Sports on.
something to check - not sure if your accelerator pedal is going out, but i was getting a pending code of p0120 Throttle/Pedal position sensor and just replaced the accelerator pedal and the modulation is much better control.
