W203 Tower Strut Bar
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
Ok, a few people around here claim they are distributors.here is a test.
Get me this part
Get me this part
The True OG Modded out W203
Originally posted by MgnFicnT
whoa, where did they get that CF hood cover
Originally posted by Harris
I can get you that part but it will not fit on a C32. Ask Jerry, he had one.
Carlsson produced a few front strut bars for show purposes only and do not sell them retail. Due to the unique strut housing assembly of the C class towers, this bar does not attach in the traditional way and holes must be drilled in the bell housing to secure it. The show bar does not support its load across the entire circumference of the strut tower and will cause deformation of the housing under extreme loads with possible cracking of the sheet metal. If your intended use is for show only, then you should be alright if you reproduce the mounting methods, but if you corner the car hard repeatedly you could have problems. Be careful not to interfere with the bearing assembly.
1996 C36 AMG, 1995 Volvo 850 Turbowagon
Originally posted by smgC32
....will cause deformation of the housing under extreme loads with possible cracking of the sheet metal....
