Tech question for Evosport or other mechs
The MB techs have changed the iridium plugs . They saw on the computer that the number 3 cylinder had misfired. Also the plugs that where removed where moist.
Since then the car is running OK, but I feel that when I stop for a red light or just dont move the engine is not 100% smooth as before.
Now here is something I noticed yesterday : the low windshield warning came on (remember I have the Evosport cooling upgrade). That is very strange because I filled it up a week ago and have not used a drop since than. So I filled it up again.
My question is following : is there some way the IC water from the IC could reach the engine/plugs if there where a leak ??
I did a visual check for a water leakage myself but I saw nothing.
Thx,
Bart
Make sure there is no where else the fluid could be leaking from, because it does not sound like a cheap fix if it is the IC Core.
1.) Leaking A/W Intercooler in intake manifold/supercharger (already mentioned above).
2.) Leaking intake intake manifold or head, between the water jacket and the intake port or combustion chamber.
3.) Leaking head gasket.
>>> It is most likely, number 1. <<<<<
One could do pressure check of the IC coolant system, to see if there is a leak. It should hold at least 6.0 LBS/sqin. One needs to seal off sections of the IC system, to do a pressure check.
It is common to do similar pressure checks of the engine cooling system, but the pressure can go to 16 LBS/sqin.
This may give you some ideas, here is a link to a simple intake air test on the Audi S4.
http://www.awe-tuning.com/media/pdf/...ure_tester.pdf
It does not take anything fancy, but a low pressure regulator, gauge and sealing off
normal air leakage paths. I would not run above 10 LBS/sqin, 6 LBS/sqin will probably find a leak, if there is one.
Just use care and common sense, when checking it.
Quick update.
The found a leak in the IC core which they have replaced. So far so good but I am still keeping a bottle of water in my trunk just in case the engine starts drinking water from my windshieldwater reservoir again.
I hope they will cover it under warranty (actually I am just 2 months past the deadline .....)
BV
