Problems with camber??? - Wheels tilt at an angle of up to 20 degrees
Old Jun 22, 2004 | 12:20 PM
Wiedermann's Avatar
NA
Exclamation Problems with camber??? - Wheels tilt at an angle of up to 20 degrees
Quote courtesy of Mercedes Benz :
"When cornering, the F 400’s wheels tilt at an angle of up to 20 degrees. This increases driving stability and reduces the danger of the car spinning. The tilt angle is controlled electronically according to speed, acceleration, steering turn-in and yaw movements. The tyres on the inside of the bend stay in their normal position, as does the car’s body.
Due to the high lateral forces exerted on the outside wheels, lateral acceleration is up to 28 per cent higher than on a sports car with conventional suspension technology. In addition, the F 400’s system can react if the car is in danger of spinning or aquaplaning, or to emergency braking, by adjusting the wheel camber as required.
Drive-by-wire also plays an important part in helping the F 400 achieve its development objectives. Automatic steering inputs can help to minimise the risk of the car spinning, while electronics allow braking pressure to be distributed far more efficiently."
This is a car that Mr CynCarvin32 could use!
Wiedermann
Old Jun 22, 2004 | 12:36 PM
smgC32's Avatar
Hey, I just saw that car on TV this morning. It was on episode 9 of the new Power Rangers.
Old Jun 22, 2004 | 01:32 PM
I1 ULOOZ
Guest
Posts: n/a
cool
Old Jun 22, 2004 | 02:02 PM
Wiedermann's Avatar
NA
Out with the steering wheel on S Classes... Steer by wire coming...
(Courtesy of auto spies reports )
The next-generation S-Class Mercedes is scheduled for our shores in late 2005 as a 2006 model. Our spies caught a body-in-white being piloted around sans doors and hood, looking a little odd. The S-Class they saw was the testbed for a steer-by-wire system controlled by a joystick mounted to the transmission tunnel. Advantages are the lack of a steering shaft for better driver safety, the ability to steer the vehicle from either side of the car, and better integration of electronic stability augmentation systems. The Autodrive system, as it's currently referred to at M-B, is slated to be introduced on the 2008 models. Other features on the 2006 models include turbocharging and a 7-speed automatic transmission.
Any thoguhts???
Wiedermann
