What is your favorite feature on the C?
... maybe a bit more practice and while doing so...What about....
-Closing all windows and sunroof at the touch of one button: (while driving).
While driving, if you have all windows opened, and even the sunroof, (with the either AC on or if you have just the ventilation on) if you hit the Recycling air button to turn it on (red light comes on), and hold it pushed, all windows that are opened and even the sunroof (if opened) will close!
.-If you did the previous test... if you press the circulation button again (ventilation or A/C must be on AND ventilation must be activated AND the previous step was done) and hold it down (to turn off recirculation), all Windows & sunroof will open up again to their previous position!
-Change/passing lane signal (3 blinks only)
If you touched the turner signal but without pushing it all the way through, the selected side (left or right) will blink 3 times (good for lane changes
)-Side mirror tilting on reverse's separate memory (3 settings)
Each seat memory can hold a different memory for the tilting when in reverse for the side view mirror
-Key change to unlock driver’s side door first, then the rest of the doors
Or it’s opposite to open all doors at once, both features that are user programmable!!!!
- Closing all windows and sunroof with the keychain
If you have all windows opened, and even the sunroof, if you push the close/lock button and you hold it down toward the Infrared sensor in the car, the car will lock, then close all the windows and sunroof (if opened)!.
- Opening all windows and sunroof with the keychain
If you have all windows closed (whether the car is locked or not), if you push the open/unlock button and you hold it down toward the Infrared sensor in the car, the car will unlock (if locked), then open all the windows and sunroof.
-Alarm "Chirp" when locking/unlocking your C32!
IF you have enabled the "Norway" setting... which is just a country code selected in the setting of the C32 --this is done by a technician at the dealer-- you can have your car "chirp" when you lock/unlock your vehicle
. If you do activate this feature, depending on the "country code" the technician selects, sometimes, depending on the country code selected, the panic button will cease to function... solution???.. to have the correct country code selected that allows "chirping" and panic button to work
That is not co count depending on the type of equipment you have, they are other features Self leveling Bi-Xenons… the list goes on and on and on…blah, blah, blah…
Any other cool things you guys have seen in your C32????
Wiedermann
The gas pedal.
