Headunit upgrade help!!!!!!
The one thing I would like to change is the head unit. Now doing some searching there is the xtron unit, and various other ones for around that $300-$400 range.
I am mechanically inclined and do most of my maintenance and work on my car but when it comes to audio I am lost.
Can you guys recommend a solid head unit that will provide me with bluetooth, descent audio, and an updated look?
Also most of them are android if I understand, are there ones that work exclusively with the iphone?
Here is one I am looking at on aliexpress? https://www.aliexpress.com/item/4000...chweb201603_55
I apologize if there are duplicate threads but I searched and they are mostly technical.
I presume C55 and C32 use fiber to the amp and speakers wires come out of amps. I have my head unit attached to via the included kenwood harness which I believe same process used for my former Kenwood DNX 7100. This time around it was a simple replacement. I don’t think they used any other harness at all. The factory amp was in my trunk. We removed it and installed 2 separate amps 1 feeds the Sub box other feed all other speakers in car I had upgraded to Diamond Audio.
There is one way around all of this. You can run speaker wires directly from each speaker to behind the dash and wire them into the new harness that comes with your stereo. This is a big pain in the butt. You will also be bypassing the harmon kardon sub and amp that is in the back when you do this.
