Hi All, hope you are having a good day. Recently I had a complete battery drain after my C55 sat a couple days. I was able to get the battery charged and then test for the power drainer and have linked it to the driver's seat control module.
Now, I have looked through many threads and saw a lot on the C32 but did not see how to re-wire the seat on a C55 to "correct" this drain issue and make the seat controls work only with the ignition on. Below I have a picture of both the driver's and passenger's control modules. On the driver's side, do I have to cut the red/yellow wire in one plug and connect it with the black/yellow on the other? That seems wrong to me, but I wanted to see if anyone had an answer for this. On the passenger's side (in case needed in future), would I have to cut the red/green and connect with the red/brown wire below it?
Thank you very much for any pointers/assistance. This is much appreciated!
