Dyno Mode didnt work :(
Cars and boats!
When i got home from work yesterday, i spent an hour trying to put the car into dyno mode (disable ESP completely) and even with all the instructions ive found on this site and others I still couldnt get it to work. And the same thing with my cousins C32!!! Anybody else have the same experience as me?
Benzo,
I heard that it is different or doesn't work with 03 and up. I have tried it on mine as well and i couldn't get it to work. I have an 03 and I tried it different times with varying levels of delay and still no luck. Anybody got it to work?
Prasith
Prasith
Turn the key to position one then hit the odometer reset button 3 times but make sure you’re quick. Use two hands! Don’t hold it down for 40 seconds! I have a C55 and it worked with that. Then u will get a setting on the display mine says like 12.3v or something like that. Look for it using the menu button which navigates through the menus. Then hit the + or - arrow and look for the on of some test forget what it was called. Dyno test maybe and turn it on then start the car and it says esp and abs failure. PM me if u need help.
