Sway bar bolt size
2003 Nissan 350Z
Sway bar bolt size
How would I know if my sway bars uses 10mm or 12mm bolts?
I had the linkages replaced recently with part (2) #913023-10002 nut, (2) 203-320-26-89 Rod, (4) 913023-012002 Nut.
All C32s are 12mm on the front swaybar ends [thus 12mm links, and 12mm at the struts].
(It is the other guys that have the confusion. The non-C32 C-class models have 10mm hardware. So when they add C32 swaybars to it, they need to chose where and how to make the 10mm to 12mm conversion.)
BTW The C32 does use 10mm on the rear sway bar ends.
