C55 H&R swaybars and headlight levelers
Old Mar 7, 2020 | 07:10 PM
brauhaus313's Avatar
asdas
Would appreciate if someone can confirm that the H&R swaybar set with the 12mm front endlink holes have flats on the bars to provision for the headlight levelers on a C55.
Thanks in advance.
Old Mar 16, 2020 | 02:28 PM
dorimaster's Avatar
ae86 and w203 wagon
Confirmed: had to bend the tabs/and u-bolts to make them fit some. Yes you do need the 12mm ends on them as well. Yes they are the BEST mod needed for these cars to actually HANDLE, you also: MIGHT need to get engine mounts-mine are shot-so i have had to space my swaybar down at the D-mounts(stock engine mounts collapse, causing interference into the oil pan.
Old Mar 16, 2020 | 04:13 PM
asdas
Thanks for the feedback
Old Jun 14, 2020 | 01:02 AM
asdas
Did you ever replace your engine mounts and find that the swaybar then clears? I installed the H&R bars and at full suspension droop the bar does contact the oil pan but my car has less than 50k miles on it. I suppose it is possible the mounts have collapsed but I think it's also possible the H&R bars aren't clocked quite correctly.
Old Jun 22, 2020 | 04:25 PM
dorimaster's Avatar
ae86 and w203 wagon
when the car is sitting on the ground the swaybar does NOT touch the pan(only when i raised the vehicle), i am going to get aftermarket engine mounts so that i dont keep tearing/ruining stock ones(they dont last) Also: i got an aftermarket loop on its way so the headlight/rideheight sensor does not contact(found it was still hitting)
Pete
Old Jun 23, 2020 | 05:18 AM
asdas
Right, as I mentioned, at full droop the swaybar contacts the oil pan. So, you don't know for certain it is worn mounts that causes the oil pan contact. I don't think you mentioned the ride height sensor was contacting anything previously. I'll have to check that out.
Old Jun 25, 2020 | 10:29 AM
dorimaster's Avatar
ae86 and w203 wagon
Id assume thats your issue:i dont know: but my engine mounts are done/bad and plan to replace with the aftermarket billet ones, you doing the same?
the reason i need to mess with ride height sensor/have contact: i have aftermarket camber and caster arms as well that interfere with the sensor, that take up the same room as the swaybar, but i got in a solution for that from the manufacturer
