ISO LSD!!!!
I don't think any E55 ever came with an LSD. Which 63 amg lsd are you talking about?
Why not just get a Quaife that is made for your car? https://www.fabtech-performance.com/...amg-quaife-lsd
Sorry meant c55. In referring to the na 63 from a w204 chassis. If I could find one that's used for a good price sure. Dont really want to shell out 1500.
I don't think you can buy just the OE LSD anywhere and doubt even if you could it would be cheaper than the Quaife. If you find one used, I would wonder why the seller would sell just the LSD and not the entire diff.
If you plan on going with an entire diff from a C63 with PP, even if it would physically fit, I don't think you can just plug and play swap because the C63 has a different rear end ratio than your C32. I'm pretty sure it would require transmission programming, possibly custom if there isn't already a compatible tune out there. Cost wise, a used diff with the LSD isn't going to be cheap either. There's one on ebay right now that claims to have the LSD, but the part number doesn't match what I see for the 204 LSD diff. The regular w204 c63 doesn't come with an LSD.
If price is an issue, I don't think the 204 PP LSD necessarily wins the day considering the cost of a TCU tune. Also, the C63 diff has a longer rear end ratio. Would make for a slower car.
Oshkoshbigjosh (06-10-2020)
Even if the C63 diff would physically fit, I don't think you can just plug and play swap because the C63 has a different rear end ratio than your C32. I'm pretty sure it would require transmission programming, possibly custom if there isn't already a compatible tune out there.
Cost wise, a used diff with the LSD isn't going to be cheap either. There's one on ebay right now that claims to have the LSD, but the part number doesn't match what I see for the 204 LSD diff. The regular w204 c63 doesn't come with an LSD. I don't think you can buy just the OE LSD anywhere.
the c32 uses the smaller/older version diff which avail from Quaife($1500) From (depending on models)2004 they use later ones and can swap in p30 package factory or wavetrac $1000ish and stronger/larger. People have swapped in the later larger diffs but it requires a LOT of parts and some custom bushings or whole subframe
2005 6spd Manual C55 AMG; 2000 ML55 AMG; 1994 E420; 2008 ML63 AMG
Mfactory makes a great one that is priced better than most. Don't waste the time trying to find one from another mb model, you will run into issues and it won't be cost efficient.
Mfactory only makes the late model/larger limited slips, and for the same money I always recommend the wavetrac over it. which is made in the USA AND has lifetime warranty! It’s just $300 more due to it being the smaller/less popular version. So that’s his 2 options(get the wavetrac) thank me later
