shifting problem?
I know the computer is supposed to adapt to the driver, but is this normal?
Thanks in advance.
also it does this after a track day for me because it learns about the track shifting characteristics and think I am just lifting to get myself right in a corner. Lifting and getting back on should keep you in gear unless you are driving pretty conservatively and then the ecu will upshift if you lift.
Just use the manual tip for 70% of your driving and your ecu keeps a pretty aggressive shifting sequence.
