slop in front suspension
Old Aug 12, 2020 | 12:28 PM
godpossessed's Avatar
2002 C32
We've had the old girl (158k) on the rack and determined that the clunk in the front is the torque struts. I am also going to do sway bar links while I'm at it. What else do I need?
Mark
Old Aug 15, 2020 | 02:40 AM
kaixdiego's Avatar
190E, C36, C55, CLK55, ML55
Sway bar bushings would be a good idea as well. More so depends on how other things appear and perform, or if you want to upgrade any components.
i did poly bushings on pretty much all front suspension and it really helped overall, but if your looking to stick with oem a refresh with the components you mentioned will probably be noticeable improvements. Tie rod ends were also pretty shot for me around 150k.
