H&R 10mm Spacers
Old Sep 1, 2020 | 02:24 PM
ceefiftyfive's Avatar
2005 C55 AMG
H&R 10mm Spacers
C55: Just ordered TRAK+ H&R 10mm spacers and am also putting 2 new rims on the rear with the spacers. I know im going to need longer wheel bolts because of the spacers, does anyone know which kinds i'll need and where I can find them?
Old Sep 1, 2020 | 03:26 PM
ricecooker713's Avatar
C63 E63
If you're using stock wheels then you will need lug bolts with a ball seat. You should search for 12x1.5 x 50mm ball seat lug bolts with the use of 10mm spacers.
Old Sep 1, 2020 | 04:40 PM
2005 C55 AMG
thank you a lot, would i need cone or ball seat with enkeis?
Old Sep 1, 2020 | 07:56 PM
kaixdiego's Avatar
190E, C36, C55, CLK55, ML55
most aftermarket wheels are conical seat. Highly recommend stud conversion if you are going aftermarket wheels https://motorsporthardware.com/produ...onversion-kit/
I have a video on my youtube channel if interested, makes things a lot easier with aftermarket wheels and more cost efficient. The only reason German manufacturers use lug bolts is cost effective to produce, one part versus two, no performance benefits.
