Suspension Kit
What are your goals? You want to slam it or you want to leave the ride height stock and make it firmer/sportier? Are you going to DIY?
Factory is Sachs, they are pretty good. Bilstein has two OEM style options, B4 (black) and B6 (yellow), both are around $100-150 a piece, both great options if you want to leave the ride height stock or slightly lowered (1 inch), B6 would give you a firmer/sportier ride than B4. I recommend replacing bushings, ball joints and tie rods if there's any play in any of those.
2003 C32 AMG, 2015 RAM 1500 4x4, 2012 Merc GL450
Koni Suspension?
I've got a set of Koni Yellows that would fit it if your interested, they're Kinda expensive, I'd let the set (front and rears) go for $600 to try and recoup some of my money, I was going to put them on my C32 but went with the Sachs, the part
#s are> Front KONI 8741 1412SPORT, Rear Koni 8041 1319Sport, if you want to research, they're still brand new,
808C32AllMyGas (09-29-2020)
eurochargedw210 (09-29-2020)
