Would like to up size the rotors. What do I need
Old Sep 14, 2020 | 03:47 PM
PJmak's Avatar
I was told its possible to run larger diameter rotors with the slk55 calipers but I would need a caliper adapter/bracket.
Can someone confirm and possibly point me towards the right adapter and rotors. Im thinking just fronts for now
I want to fill in that empty space inside the wheel when the rotor change comes around.
Old Sep 14, 2020 | 06:49 PM
eurochargedw210's Avatar
w210 E55
Not sure if you can run bigger rotors with the SLK55 calipers. Message CM60K
Old Sep 15, 2020 | 05:51 PM
robbyt18's Avatar
C55, w211 E55, ML320 CDI
I think you have these rotors: 171-421-01-12 340 x 32mm 2-piece rotor.
But you want these from the CLK63 and SLK55 030: 209-421-01-12 360 x 32mm 2-piece rotor aka Brembo 09.9547.33
Those are designed for a different caliper. Not sure about adapter/bracket.
