W203 C180 Drive Jerk Problem
I recently bought W203 C180 2006 model. Such a nice car even in 2020s.
I am facing an issue with driving. No matter if it is set to "D" or I am driving it manually, car starts to jerk in low RPM both when accelerating and when coming to a stop. It doesn't matter if it is a cold start or if the engine is warm.
I have seen different solutions in different threads here. Valve body has been replaced thrice, I mean three different valve bodies were tried but the jerks persist.
The mechanic has replaced all the three foundations already.
Any help/hint on this matter will be hugely appreciated as this issue is driving me nuts.
Thanks a lot for your time.
This is the C32/C55 forum which your post will not, more than likely, receive any responses. Please post your issue in the C Class forum and I'm sure you'll find other C180 owners that will help you! Good luck!
Rob
