Options for C32 ecu
Old Jan 21, 2021 | 12:48 AM
Benz C32's Avatar
‘02 C32 AMG
Options for C32 ecu
Just heard back from the auto electrician that the ecu is water damaged.
C32 ecu's are quite expensive in my area at about $1000, are there any other ecu that is compatible? Like c320, c280 etc.
I understand that it will need to be renewed/virginised
Old Mar 1, 2021 | 11:33 PM
michobebe's Avatar
W220 S500 2003 4Matic & W140 1998 S600 V12
depending on what went wrong with it, i just had the same problem, my electrician resoldered a bunch of contacts, cleaned some, and had some components transfered from a donor ECU (of course I'm talking about the random ones, not the programmed chips.
Make sure you front SAM has not had water in it too. After I repaired my ECU my car still didn'T work until I realized my SAM needed changing too
