Oil in tcu, 2002 c32
Old Apr 13, 2021 | 01:36 AM
Jcruz559's Avatar
W203 C32 amg
So I replaced shifter module conductor plate because the car wouldn’t shift out of first didn’t resolve the issue. However after inspecting my tcu I noticed there was a lot of oil that had leaked onto it so I cleaned the connectors with electronic cleaner. Am I supposed to reset the tcu after ? Or clear the code?
Old Apr 13, 2021 | 02:10 AM
alb3rtt's Avatar
2002 C32 AMG (SOLD), 2004 C55 AMG
Clean the TCU while you're there since the oil could have gotten through and unplugging it should clear the code but manually clear it if it persisted.
Old Apr 13, 2021 | 02:42 PM
Jcruz559's Avatar
W203 C32 amg
I cleaned tcu connectors and harness connectors. What I’m asking is if I’m supposed to reset the tcu via scanner or should the code go away after a simple clean and unplug/plug in?
