M113 Engine, C55 AMG alternator
Old Apr 29, 2021 | 02:48 AM
Biig AMG's Avatar
2002 S55 AMG catless, x pipe, Brabus mufflers, coilovers, and driven like hell
Is anyone an M113 specialist? I know my way around the motor well, but I need to know if the alternator from the 2002 S55 AMG and 2006 C55 AMG are interchangeable. My C55’s alternator went out and my S55 is down. Wondering if I can swap the N/A S55’s alternator over into the C55. Main reason I ask is because FCP euro says they’re different part numbers, but fit in both chassis. So I’m very confused.
Old Apr 29, 2021 | 10:42 AM
Robjr's Avatar
Veteran: Army
2005 Mercedes Benz C55 AMG..1967 Lotus Europa..1987 Lotus Turbo Esprit HCI..2020 Mercedes Benz E350
Biig AMG....
You may not be aware but there may be a chance the regulator has gone bad which is a replaceable part which is located on the back of the alternator. Alternators, non-dealer cost of $240+/-) rarely go bad, its generally the regulator. I had the same issue about 5 years ago at 90,000 miles on the clock. You can check FCP Euro, Parts Geeks, Pelican Parts, etc. I think I paid $36 for it and it was a 45 minute job as you'll need to remove the 1st panel from the front to get to the alternator (disconnect battery negative cable). Then its simply remove and replace (R&R) the regulator, replace battery cables, and button up the bottom panel.
Good luck
Rob
