Battery drain—2006 c55
Old Jul 3, 2021 | 04:35 PM
rwolak's Avatar
2003 CLK500, 2008 e350
What would cause the lights in the middle of the dash not to time out? I can shut the car off, remove the key, and close the doors. The doom light fades out but the display in the middle of the dash, I.e., mileage, time, etc., stays on. Does not timeout.
any help will be appreciated.
Old Jul 3, 2021 | 06:10 PM
Oshkoshbigjosh's Avatar
2005 S55 AMG Designo, (sold)2001 ML55 Designo, (sold)2004 C32 AMG, RIP 2005 Volvo s40 2.4i
Your best bet is to either check fuses/relays or remove your cluster to see if the harness is compromised. Is it just the screen or is it the warning lights too?
Old Jul 3, 2021 | 06:19 PM
rwolak's Avatar
Just the center of the screen. Normally, it would go on when the door is opened, then timeout when door gets closed.. The mileage, time, temperatures are illuminated. I pulled the fuse, 7.5a, cleaned the terminals and replaced it. Of course with the fuse out none of the gauges worked, along with the lights.
Old Jul 3, 2021 | 06:24 PM
rwolak's Avatar
Is there a relay that controls the timing to extinguish the center lights?
