C55 amg w203 fender bonnet bumper w209
And as for the bumper w209 halogen grilles, the middle grille and the round halogen from the c55 w203 will fit the w209? sorry for errors translator.
The fenders are specific to the C55 (the back seam is different where it meets the doors), as are the fog light grills (see above).
The hood from a CLK will fit perfectly, but is slightly different because the C55 has an upper chrome grill strip that has 5 studs to mount it. Most people put the CLK grills on anyway. I understand the latch assembly is slightly different because of the grill. Shouldn't be a problem if you go with the CLK grill. The upper grill strip is unobtainium. I've never even seen it used on eBay, as most wreckers sell it as part of the hood. I can get you part numbers if you want for the correct grill parts.
I will try to install the halogen grilles and the measure from the original c54 w203. greetings
Friend has a 06 clk500 which has slightly different bumpers. They are more pointy. Older clk500s have a bumper that looks like the c55. Was the 06 year changed a bit on the clk?
