C32 AMG (W203) Trans Help
Old Apr 22, 2022 | 03:51 PM
Nick Facchini's Avatar
2003 C32 Amg
Hello everyone, I have a 2003 C32 Amg thatis continually throwing code “P0753”. Solenoid A has been replaced as well as the conductor plate twice now. It will not go into winter mode or shift, it’s filled with fluid and I have done everything I could to clear the codes but after 2 heat cycles the code always come back up. I have run out of ideas and am considering swapping it to the Chrysler 6-Speed MY that’s been done one or two other times, I’d anyone has any ideas for a solution, please let me know!
Old May 19, 2022 | 03:26 AM
mrkevinhoang's Avatar
s500 2006
Did you get this sorted out? I had a smiliar code in my 722.9 trans and replcing the valve body plus cunductor plate fixed it. There's also a plastic tube on the valve body that connects teh body to the trans. without it, the w /s wont work. (at least in the 722.9, but maybe similar to yours)
