C32 amg front camber question
Old Jun 30, 2022 | 01:53 PM
c32amgzeeland's Avatar
C32 AMG
Hi Everybody,
I have a question about the front suspension on my 2001 C32 AMG.
I've replaced the left lower control arm(lemfoder), the inner and outer tie rod. Also I've replaced the bushings in my lower and upper control arms from standard to powerflex bushings.
When I went for an alignment the front camber of the left side was 'way' off. -2,05 (picture)
To make sure the size of the control arm is correct I've ordered an original control arm to compare.
I do know there are camber bolts available for the original bushings, but it is not possible to use the bolts with the powerflex bushings.
The bushings have a hole that is the exact size of the bolt. (pictures)
Is there anyone who has an idea of getting the camber on the right side? even when I want to use the powerflex bushings?
Or is the only option to go back to an original bushing in combination with a mercedes camber bolt?
And if so, how much camber is ajustable?
Kind Regards.
Wilco
