Evap Canister Shut Off Valve
Old Nov 2, 2022 | 07:33 PM
Robjr's Avatar
Veteran: Army
2005 Mercedes Benz C55 AMG..1967 Lotus Europa..1987 Lotus Turbo Esprit HCI..2020 Mercedes Benz E350
Question for any Gainfully Employed MB Tech:
Do you know why the Evap Canister Shut Off Valve, which sits on top of this canister that is located behind in the right rear wheel well liner, is tilted 35 +/- degrees to the right instead of a straight up and down vertical position?
Clearly, based on the amount of room above the shut off valve, it could easily fit in a true vertical position. Any reasonable explanation would be appreciated!
Rob
