Code3 intake DIY
I measure the size and it’s a 120mm square with 105mm center to center bolt holes. I know that it will mount into the top two holes perfectly and this would be able to sandwich inbetween the stock cover once I cut it out. I looked at the DIY from the srt6 forums and everyone’s using chicken wire but looks sketchy. Any help would be appreciated.
They allow approx. 600 CFM and can be modified to fit in the C32, you can also increase the CFM by lifting the air filter using an expansion ring that raises the air filter in the intake housing. Good luck
