722.6 transmission issue after replacing transmission fluid and conductor plate
I replaced 2005 C55 AMG transmission fluid and conductor plate. I extracted 3.75 L of old transmission fluid. I added about 3.5 L of new transmission fluid. I am using the Launch x431 Pro V5 diagnosis tool. Erased all codes. Reset the adaption. No DTC code.
Both the dashboard display and hand gear shifter (Selector Leveler) are the same (no issue). However, when using x431 to monitor the gear selection, the "actual gear" and "target gear" are different. What should I do now? Please help and thank you all,
*I misunderstood the instruction for measuring trans fluid. After I topped it off, it shifts and runs sharply! thank you all!!
