M112k rod bolt torque specs
Old Aug 18, 2023 | 07:39 PM
cdk4219's Avatar
95 SL600
Anyone know what the rod bolt torque specs are for the m112k. Getting some new rod bolts and going through the bottom end on the engine.
Old Aug 18, 2023 | 10:58 PM
Stephen04E55's Avatar
'09 CLK550, '18 AMG GTR, '06 C55 AMG, '25 GLS450, 09 E63
m112 & m113 should be the same...I found the rod bolt torque to be 75nm in three steps. 25nm, 55nm, 75nm. Hopefully someone can confirm this #.
Old Sep 5, 2023 | 05:53 PM
cdk4219's Avatar
95 SL600
I believe most Mercedes rod bolts are torque to yield, and the last procedure is 90degrees. Anyway I found this on the 112 and 113 engines, 75nm seems to be quite a bit for that little fastener.
