C55 vs M3 - Another 5 unimportant reasons ...
A member of this board with a C32 (Dracco) as posted his experiences at the strip & he also witnessed an M3 vs C55 at the strip while he was there. It was one win each to the M3 & C55. The C55 seems to be marginally quicker than the C32.
It must be noted that that particular M3 driver did not know what he was doing & me & my buds beat him by 0.3-0.4 seconds consistently. His 60ft times are 2.2 & above.
But being the generous person that I am, I accept that he may be representative of most M3 drivers out there. Even then he is still quicker than a C32 & about even with the C55.
So can we rest this subject now?
so what did ur M3 pull at the track?
But being the generous person that I am, I accpet that he may be representative of most M3 drivers out there. Even then he is quicker than a C32 & about even with the C55.
Dracco posts his experience, and you believe it.
I posted in my post that I'd run an E46 three times in a row from 80-140 last week. Do you believe that?
Do you believe the testimony of the following people, whom (as this makes it three times I've pointed this out to you now) are all BMW M3/M5 owners??
E46 M3 owner vs. his Dad's CLK55: four races, four wins for CLK55
E46 M3 owner: two races, two wins for CLK55
E46 M3 owner: multiple races, M5 vs. M3 vs. CLK55; CLK55 wins all
M5 owner who switched to CLK55 reports CLK55 is just as quick
M3 owner reports runs with W210 E55: dead even race
(note that W210 E55 is about 300 pounds heavier than W208 CLK55, with same HP and gearing, so from a roll CLK should be quicker, i.e., based upon these results it would pull M3)
add another E46 M3 owner to the list:
add still another E46 M3 owner to the list:
And you keep insisting that "all" magazines in the world have shown the M3 faster. Rubbish. Again: this makes it three times that I've pointed it out to you now that this claim is false:
Motorweek's test of CLK55 AMG: 13.4@107
Motorweek's test of E46 M3: 13.5@107
Edmunds' test of CLK55 AMG: 13.48@106.3
Edmunds' test of M3: 13.5@105
And there's an explanation for this: LSD. The M3 has an LSD, 262 lb-ft of torque, and 255mm tires; the CLK55 has no LSD, 390 lb-ft of torque, and 245mm tires. Gee, M&M, which one o' them thar cars do you think has a launch advantage? The fact is that while you can dump the clutch on an M3 at 2,000 rpm and get a good launch, if you try powerbraking the CLK55 or C55 at 2,000 rpm, you'll get spin all through first gear.
Motor Trend alluded to the traction issues in both the W210 E55 and the CLK55 when they compared them to the M5 and M3:
Read the following M3/CLK55 comparison test from Motor Trend
With nearly identical curb weights and horsepower, this pair runs comparable 0-60-mph times-5.02 sec for the M3 and 5.23 for the CLK55. The difference closes slightly at the end of the quarter mile, with the M3 recording a 13.63/103.76, while the CLK55 runs a respectable 13.74/104.44. MT test driver Chris Walton noted that the CLK55 produces lots of wheelspin off the line, while the M3 stays better hooked up. The CLK's five-speed automatic transmission performs nearly perfect shifts, thanks to the Touch Shift manumatic gear selector. However, Walton found it harder to drive the M3 once it gets rolling because it's easy to hit the 8000-rpm rev limiter on the 1-2 and 2-3 shifts of the six-speed manual transmission. A possible solution is BMW's optional Sequential Manual Gearbox ($2400). Derived from BMW's F1 cars, the system uses a manual transmission, an automated clutch (no pedal to push), and steering-wheel-mounted shift paddles. Despite being down 114 lb-ft of torque, the M3 won our acceleration test by a hair, thanks to better traction and even more aggressive gearing.
Not convinced? Read Read the following M5/E55 comparison test from Motor Trend
These cars aren't quick. They're genuinely fast: The M5 blisters 0-60 mph in a 911-like 4.6 sec. The Mercedes stays in the fours by 0.01 of a second at 4.99. The BMW's approximately 4/10 advantage hangs on through the quarter mile (13.08 at 109.41 mph versus 13.46 at 106.71). The difference isn't so much the old saw about power losses with an automatic transmission as that the Mercedes was all too happy to just smoke 'em at the starting line. In spite of a clutch that takes some practice to be smooth with, Senior Road Test Editor Chris Walton actually found the M5 easier to launch.
It's not a case of being overpowered: it's the all-important 60' time. The LSD in the M cars helps their 60' time. The fact is that it takes a great deal of skill and practice to launch these AMG cars without excessive spin. But it can be done, and when it's done, the M3's go down.
And from a roll, you see, or in the 99% of cases wherein the M3 driver doesn't launch perfectly, it is different, as the testimony of myself, and other C55/CLK55/C32 drivers, shows to those who are willing to listen.
Now you claim that in your case, you have pulled the C55 handily from a roll. Fine. This certainly doesn't gel with my experience, but maybe your car is a factory freak (or maybe mine is), but that hardly means that myself and the BMW owners whose posts I linked to above are liars.
So, you want a truce? Fine. Start by saying, for the record, that you accept my account, those of the BMW owners above, and the Edmunds/Motor Week tests I cited.
Further, the guy in the first post I linked to took a lot of flak from his BMW owning peers for stating that he lost to his dad's CLK55, but he stuck to his guns. And there were a lot of people who'd met him on that board...the guy who ran the W210 E55 vs. the M3 and M5 was also a longtime poster on that board.
Car & Driver has also tested the E46 M3. From their June 2001 article: As it does, the M3 pulls like a demon, passing the 60-mph mark in 4.7 seconds and tripping the quarter-mile lights in 13.4 seconds at 106 mph.
They also tested it again in May 2003: In its 4.8-second sprint to 60 mph, it showed taillights to the others, and it stayed ahead all the way to 150 mph, albeit with a tight margin; quarter-mile time is the same for all at 13.6 seconds. (all being the S4, C32, and M3)
Note that even though it was faster to 60 (thanks, as I noted previously, to its LSD and wider tires' traction), the C32 tied it in the 1/4 at 13.6.
Also note that the C55's 1/4 time is faster than both times C&D obtained in their tests of two different six-speed manual M3s.
So much for "all mags showing the M3 faster than the C55".
I would love to see you put a thorough response to Improviz's posts
But I have no problem with Improviz's post. Its probably true. Problem is, I could go through BMW forums & dig up even more posts where the opposite has happened. Actually if I had time that is exactly what I would do. There was a guy on the one forum that bought an M3 & his dad had a C32. They went & tested ont he highway & he walked his dad easily. Then they swapped drivers & his dad walked him with the M3. What does that prove?
I have run 13.0 @ 108 bone stock. Lee Rutter had run 12.72 with a bone stock e46 M3. His exit speed wat 107 & his 60ft was 1.71. Those speeds prove the car was stock. Anyway his car now has minor mods & runs 12.4 @ 112. Who want links?
HEre's a guy with a stock SMG M3 that ran 13.0:
http://www.m3forum.net/m3forum/showt...ight=post+pics
What does a stock C32/55 run. Definitely not better than 12.72. Why don't you guys just show some intelligence & concede that its possible for a strong stock M3 with a good driver to beat a C32/55?
There are things that can be done with the tyres on a stock car (if the engine really is stock that is, it'd be eay to put in a chip and no one would know) than can improve the launch, but these don't influence a rolling run.
Anyone who says the M3 will walk a C55 from a roll is well a bit optimistic IMHO, but the M can win from a standstill as proven by various magazines.
hv u posted links about cantonese mags showing the M3 is quicker?
lession for u once more, dont be so dramatic when you show how quick ur ride is
Now, in order to catch a car that's jumped you a length or 2 off the line you need more horspower than him. If you have 1 more hp you will never catch him. You need a significant horsepower advantange to catch another fast car from behind over 400m.
On a rolling run the traction advantage of the M3 is negated & its a closer battle.
It's funny how much BS comes out of your mouth.BTW, i sold the M3 because i wanted something else...going back to my roots (off-roading and long-distance traveling).
I don't read much US magazines but UK Autocar clocked 343bhp Euro spec M3 in 13.7s (400m) and 0-160km/h in 11.5s and 354bhp Euro Spec C32 in 13.0s (400m) and 0-160km/h in 10.9s.
I have both E46 M3 SMG and C32 and I've pulled them side by side with a help from a friend. M3 was launched using launch control and result was both car were even at 400m. But C32 will creep away from M3 from 200km/h. Trust me both cars are quite evenly match and most of the time it's the driver that makes the difference.
Of cos I do not rule out the possibility there are some slightly faster and slower ones out of the factory. I'm sure if you pulled a few identical M3s or any other cars, you'll bound to get some faster and slower ones.
The only M3 my C32 had lost to is a 360bhp M3 CSL which is about 200lbs lighter than standard M3.
BTW both my cars are bone stock.
And you are right that no 2 cars (or drivers) are the same. On the thread I posted where the guy with a bone stock M3 SMG got 13.0 on 3 consecutive runs, there was mention made of another guy with some mods to his M3 SMG. he has chip, exhaust, etc. He ran a best of 12.9. So some cars are just faster stock than others.
Eric...
Eric...
:p You just had to add that last part in, didn't you? All he asked was whether the SLK55 was quicker than an M3.. Some of you BMW guys can't simply answer the question and have to end up with BMW somehow on top.. Yeah the SLK55 should beat an M3, but not for long... lol you guys crack me up sometimes..
Eric....
so your best run was 13.0 @ 108mph and your buddys 12.7 @ 107mph.... and you think u can beat a stock C55 under teh same conditions?
I already put a deposit down on one.
For now, I guess we will all have to drive the vehicles CURRENTLY IN PRODUCTION.
