Help!! c32 misfire and small evap leak
Old Apr 7, 2024 | 11:24 AM
c32nate's Avatar
2007 c280 4matic, 2003 c32 AMG
Hello fellow Mercedes enthusiast i purchased a 2003 c32 AMG the other day with zero issues but while driving home when i pressed 100% of the gas the car lost acceleration, jerked, then went into limp mode and threw a misfire code for cylinders 4, 5, and 6 and a small evap code P0446. if i restart the car it drives fine only if i punch it. the fuel pump, and spark plugs were replaced but no change. a compression test was also done and everything seemed fine. if i clear the misfire codes the car runs fine with no check engine light. any suggestions on what to try. thanks!
Old Apr 7, 2024 | 05:47 PM
cdk4219's Avatar
95 SL600
Possibly the throttle pedal is overextending if it only happens under full throttle. It’s an issue with these pedals.
Old Apr 8, 2024 | 10:23 AM
c32nate's Avatar
Would you know a way to diagnose this issue or if i could use any w203 pedal thanks!
Old Apr 9, 2024 | 07:32 PM
cdk4219's Avatar
95 SL600
Does the car only go into limp mode under 100% throttle ( push it all the way to the floor?)
