Why does heater always blow cold air, even when set to 78F?
Old Nov 20, 2004 | 03:09 PM
m444's Avatar
Audi C7.5 S6
Even turning off the AC switch, it still takes a long time before the heater will blow moderately warm air. The engine gets near 100C, but still only gets cold air, most of the time.
My S4 Audi heater worked way better than this.
Also my wife's Camry heater works excellant.
It seems like a programming problem with the AC/Heater control unit.
Old Nov 20, 2004 | 06:34 PM
rguy's Avatar
I have the same problem on my C55 and didn't on my clk430. This is strange indeed. It is definitely on tap though because when you front defrost, the fog is con in like .5 seconds.
Old Nov 20, 2004 | 09:47 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
you have to turn the blue knob off so the center vent will blow warm air...other wise it'll always blow cold air.
Old Nov 21, 2004 | 01:12 AM
cntlaw's Avatar
C55AMG W203; 330i E90
Can't tell why . My 35 years MB garage experiene friend told me the MB air cond auto design is based on mixing warm and cool air depending on change of outside and inside temperature. The C55 air cond that I have , will even take the sun 's radiation into factor. That's German style, they won't explain and that 's what they think it is good for you.
Every time I found the auto mode is too cold or too warm, I simply override the auto mode. Why bother to srcratch your head?
Old Nov 23, 2004 | 11:22 AM
EKaru's Avatar
Porsche
Sometimes when I drive I have the windows partly down with the heat on... What I find annoying is when the heat is on max it's blowing hot air (as it should), but when I move the knob one click lower the air is cool (even though it's still clearly in the 80s range).... The C32 also had the same problem, but I never encountered this issue on other climate controlled cars...
Eric...
Old Nov 23, 2004 | 12:48 PM
cntlaw's Avatar
Eric...
I really had given up long time to understand MB 's air cond settings.
The "auto air cond" on my W210 was similar to the C55 in a way that it is "not cold enough" unless the weather outside is real hot.
I found the auto gets confused when the temperature is kind of "in between"; say 22c , that neither give warm air , nor it is cold enough.
I am sure ppl in cold countries will find the opposite - i.e. "not warm enough"
The hint is don't trust the reading on the LCD.
Let's get used to not using the "auto climate".
Old Nov 24, 2004 | 02:15 PM
99SlvrC43's Avatar
1998 Silver C43
Eric...
Same thing happens in my C43.
