Coolant Capacity for C32
Aaron: WIS lists total capacity at 10.5L. Since you will not be able to drain all of the coolant out of the engine and cooling system, two gallons (7.75L) should be enough to refill. Make sure to use MB only anti-freeze.
C32
Is there a particular reason why I should use MB coolant? I was planning on using Engine Ice, which has anti-corrosive agents in it.
I am not 100% certain that aftermarket anti-freeze is exact match for MB's. One of the local techs at MB dealer was very adomant about using MB only antifreeze, so that's all we use. It's not that much more expensive than anything else.
