Like to know C55 Tire Pressure F33/R37 psi is minimum ?
Old Feb 7, 2005 | 04:26 AM
cntlaw's Avatar
C55AMG W203; 330i E90
Like to know C55 Tire Pressure F33/R37 psi is minimum ? And, what is max.?
I am still using 18" stock Pirelli tires
Old Feb 7, 2005 | 02:09 PM
rbaker's Avatar
Z06, M3, Mini Cooper S. Sold: C55
I don't know why, but many car MFG's reccomend stupid tire pressures. Look at the tire size, load carrying ability, and weight distribution of our cars & tell me what makes sense about 32F and 37R??? Nothing, unless you want to guarantee the front end feels like a soft pig & loses traction first.
Since our cars are very nose heavy & have small tires on the front, they respond better with more pressure up front and less in the rear. currently I am running 36-37F and 32R. It makes the front feel a little stiff/harsher, but it handles better. When I took delivery of the car with the stock setup it didn't handle as good as my 2002 BMW 330i (well it still doesn't, but it's better now). Keep in mind my car currently has Continental CS2 tires, and the exact correct pressure does depend on your tire design, but these should be in the ballpark.
Old Feb 10, 2005 | 10:15 PM
Nimbus's Avatar
Alot of cars
33/37 is the recommended pressure from the factory, it is not the minimum. The maximum tire pressure is labled on each tire if you go look at the sidewalls closely.
Old Feb 10, 2005 | 11:55 PM
BenzoAMGpower's Avatar
Cars and boats!
i run 37psi in teh front and 38psi in teh back... then i drop to 29psi in the rear when im gunna race
Old Feb 11, 2005 | 12:00 PM
cntlaw's Avatar
Amazing ! 29psi in the rear ? Must be pretty soft and sticky right ? Would that slow you down for 0-100?
I had a go today with the new pressure 33/35 with 4 persons in the car.
I found the acceleration is slower but the car seems more stable when cornering. It 's definitely less bumpy.
cnt
Old Feb 11, 2005 | 12:04 PM
cntlaw's Avatar
It rings my bell !
I probably will try to put the front to be 32-33 and put the rear to 33-34
I agree , 37 for R does not make sense , too much rattling when hits the bumps.
cnt
