99' C43: How Low Can I Drop It B4 Tire Rub
Old Mar 13, 2005 | 09:21 PM
ZZAMGZZc43's Avatar
I just bought a 99' C43 and wanted to know low I should drop it. I want my car to be pretty low but not to the point of my tires rubbing. thx
Old Mar 14, 2005 | 01:44 AM
Teck's Avatar
C 320 CDI 4M W204 / C43 AMG (W202) / C 220 CDI T (S203) / ZX-10R Ninja
Hi and welcome to the board. Congrats on your nwe ride. I'd say do with #1 pads and Brabus springs....oh yeah and it depends on what for wheels your're using. If you're using 17'' or 18'' my combination does work fine also with some 19'' wheels!
BTW post some pics of your new ride!
Old Mar 14, 2005 | 03:28 AM
KenzBenz's Avatar
1995 C36
also will depend on the width of your rims and what tires you run front and back.
Old Mar 21, 2005 | 03:12 PM
Tump43's Avatar
2014 E350 4Matic
I dropped mine 1.3" front and rear with Eibach Pro Kit springs and Bilstein Sport shocks. (1 finger gap between tire and fender, rear tire looks tucked.)To keep from rubbing w/ 17" x 8.5" ET 35 AMG composite 203's at all four corners with 245/45 ZR 17 's on them I had to use #4 spring pads front and rear.
Each factory C43 sits differently, however. That is why MB has pads #'s 1 through 5 and uses different pads and combinations on each individual C43.
I'm now moving to 245 40 ZR 18"s w/ OZ superleggera 18" x 8" ET 35 rims and will keep the same spring pads to start with. I will adjust as necessary.
Good Luck! (These cars handle a lot better the lower you go).
