suspension replacement
My 1995 c36 has a wobble and rides very loose all of the front end bushings have been replaced within the last 10,000 miles could it be time for new shocks if this is the case what should I replace them with, any help would be greatly appreciated?
Someone more qualified than I will answer this, I'm sure -- but I can give you a simple shocks test: push down quickly on either the surface of the car above the fender/wheel, or on the bumper, and release quickly. If car immediately rebounds back up from the shove - your shocks are not worn out.
