remove engine cover
remove engine cover
hey guys, i've got a new question for u it's about the engine cover?how do you gyuys take it of=? I don't wan't to destroy the engine cover on my C43 AMG, can u post pictures or discribe how to take it of=? this is good to know when i'm going to replace my MAS sensor. i think the front part of the cover is connected on a hook and in the middle there are plugs to pull up carefully=?
how do i take it of in the front and the rest of the cover? thanks
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
how do i take it of in the front and the rest of the cover? thanks![drive](https://mbworld.org/forums/images/smilies/driving.gif)
BMW and Mercedes
the rear portion (once you have popped off the front half) just clips onto 4 bushings at each of the 4 corners of the cover. Simple clips that will release with a good tug. Just make sure that you have them all lined up when you put it back on, and don't try and pull the cover off w/o disconnecting the intake runner tubes
From there you can unscrew your airbox if need be w/ an allen wrench (if I remember right)
