pulled codes on my c43 amg at the stealership
These are:
#BAS: not working (with an exclamation sign on paper=!) N48? can not reach data.
#ENGINE E.C.U. C.E.L. This had a big letter F on paper meaning it's a current fault today.
P0170-02 Right cylinder bank automatic mixture blend something?
P0173-13 Left cylinder bank automatic mixture blend something=?
P0170-02 Right cylinder idle?
P0173-13 Left cylinder idle? everything idles good?
#ESP code C1504-00 System disconnected, steerinng angle sensor not initialized. When i press the button it iluminates,when i slip with my car it iluminates automaticly on the speedometer.So it works, small letter f.
#DBE code B1010 voltage to low, something to do with sunroof? small letter f
# EGS code 146 electronic trans module, unauthorized gear shifting,what does it mean i often shift manually from 1 to Drive (5). small letter f.
#KLA klimaautomatic, code B1416=A31m1 circulating pump
code B1419= A9k1 electromagnetic connection, on both these it's a small letter f.
#there was something with the BOSE system too it dies it self, on radio,tape,cd-changer,mechanic reset this faulty code but it died again twice after reseting it,so there are still electric gremlins with this.
The mechanic could not reset the above engine codes, my car runs fine on start,idle and it's ok on the road so is this the infamous M.A.F. that is busting my chops.
Pliz anyone of you fellow c43 owners pliz let me know what all this ****ty codes mean in plain english cheers mates
These are:
Quite a list you got there. Unfortunately if one thing is off you get many codes...after I put my Green Filters in I didn't put the Intake back on lined up properly by accident and I had the check engine light on. I fixed it quickly, went to autozone to get it read, and I had like 10 codes haha. I can't explain these to you, just thought I'd share my story...
These are:
the only other fault code worth checking is the circulation pump. Just check that you can get heat if you put the a/c in "rest" mode with the engine hot but off.
the rest are irrelevent codes (if you haven't noticed anything else not working), they just appear over time
