Battery sudden death?
I pulled into the garage last night and stopped the car after a 12 mile drive home from work. I then remembered my dry cleaning needed to be picked up, so I went to start the car again and ... tick tick, CEL, nothing. I turn it to the off position, try again and only the dash lights - all of them - came on. Nothing else would work. What seems odd about this is how it was fine earlier in the day and then just died. I put a charger on it over night, but it doesn't even have enough juice to run the headlights. My 190 battery went slowly and I knew it was happening long before it died. The e430 hasn't shown any signs, but is a 7 year old battery and my wife will have my nuts if she gets stranded.
So... is this normal behavior or is it likely something else?
I've had others that were starting to crank slowly and just got too weak to operate the starter.
Often what happens is a cell dies or shorts out and that will put the whole thing out of commission.
For your older battery, have it load tested - it will show how deep of a charge it is holding. Very hot weather or cold weather will kill off an older battery that is getting weak.
Just had my 6 1/2 year old battery tested - still shows good, but it is about 98% of voltage under load...so I'll have to watch it for any signs of getting weaker.
This leads to another advantage of having a trunk mounted battery because it's cooler there than in the engine compartment.
BTW: Although the newer small appliance batteries (AAA, AA, etc.) batteries have better shelf life than decades ago, I still keep them in the refrigerator until I need them.
I have even looked for possible new batteries for my C43 in anticipation - or to replace before the inevitable happens. I would like an Optima, but a search of their applications indicates that there is not one for the C43. Has anyone used an Optima from an alternate application in their C43?
Thanks,
John
Thanks,
John
