Brake Pad question
I am very curious about my brakes. I got front pads and rotors replaced for about $840, 2006 April, and still going.....
Is that normal? Brakes work just fine, I do not drive agressively. Should I expect a brake light or something to come up when it is time?
Also how many sets of brake pads last with front rotors? I want a second opinion, cause my mechanic said, usually 3 sets of pads last with 2 set of rotors. Is that accurate?
Thank you in advance
(little note, I was not accurate on my mileage, i bougth the car 2 years ago woth 76k, and now I have 89k.)
The rotors will last for more sets of pads if you drive gently. Generally you only replace them when they are worn to minimum thickness.
