Anyone else change the front Oxygen sensors on C43?
Old Nov 8, 2007 | 05:06 PM
98C43AMG's Avatar
1998 M/B C43 AMG
I have the check engine for both front Oxygen sensors, codes 130, 150 and 155 if I remember correctly (one code for the heater element). Has anyone changed these before? I took a look at them and they are pretty crammed in there. Any tricks?
Old Nov 9, 2007 | 05:34 AM
KJI3jflarryfe93's Avatar
hey buddy i changed them on my c43 the first on was busted on the front left side, transmission sucked when this o2 sensor was bad,after i put the new one the transmission shifted like a trans when it works properly at its best, after a while i changed the front right one so everything is new.Funny thing i only have oxygen sensors at the front not the rear ones they are plugged, USA have 4 of them, Europe has 2 of them
Old Nov 9, 2007 | 08:02 PM
MBHustla858's Avatar
they are best installed from the bottom, definently not from up top. you'll need a stubby 22mm wrench to do this efficently.
i did both in about an 45mins on my back in the garage.
Old Nov 10, 2007 | 02:06 AM
98C43AMG's Avatar
1998 M/B C43 AMG
Awesome, thats the answer I was hoping to hear, no major disassebly required, I got a little nervous looking at the driver side up above the steering assembly. I actually cleaned the MAF Thursday, reset the codes and the Check Engine hasn't come back on, it's been over 100 miles. It usually came back on within 5 mins or about 5 miles. I'll give it a day or so more and hope for the best.
