C36 MISFIRE
Old Sep 3, 2008 | 12:07 PM
1994 C36's Avatar
C36
C36 MISFIRE
Hi guys my C36 has developed a misfire when you start up from cold it idles ok but when touch the throttle i get misfire at low rpm but when its warmed up its ok any ideas
Old Sep 3, 2008 | 12:13 PM
SeeKlasse's Avatar
'98 C43 AMG. Obsidian Blk w/2 tone slvr/blk interior
one of your 3 ignition coils is on its way out. either that or really bad MAF. read the codes and get back to us. you can pick up an OBDII code reader from walmart for 90 bucks... or 70 bucks online... walmart is usually the faster option.
im leaning towards the ignition coils as i have replaced a total of 6 coils between my two c280's. hope it helps.
good luck
Old Sep 3, 2008 | 06:56 PM
Z06EATER's Avatar
1997 C36AMG
yea seeklasse got this one down, check them coils
Old Sep 3, 2008 | 10:11 PM
AMG140.6's Avatar
Stg3 B5S4-C55 AMG
For one thing he's got a 94 which means he's not here in the US.
So no Wally world for him.
But it does sound like a coil has s%it the bed. Easy fix.
Old Sep 4, 2008 | 09:01 AM
1994 C36's Avatar
C36
Thanks for the replys i'll get a code reader on it next week
Old Sep 23, 2008 | 08:03 AM
1994 C36's Avatar
C36
Its been a while i ordered a code reader from the US any its just arrived today its says plug it in under the dash i've had the panels down under the steering wheel and under the glove box can't a plug anywhere i've even looked under the bonnet can't see it anywhere if i had hair i would pull it out but i know you gays can point me in the right direction
Old Sep 23, 2008 | 10:33 PM
SeeKlasse's Avatar
in my car and most others, your obd port should be directly near your right knee when you sit in the car normally. on the underside of the dash on the right side of your steering wheel.... thats if you have a left hand drive.... im assuming everything would be reversed in a right hand drive car
