bigger injectors?
1997 C36AMG
bigger injectors?
i'm thinking of installing bigger injectors in my car.what you guys think? i heard a C36 pulling 306 Hp with bigger injectors a tune, and a highflow cat...
you think bigger injectors are ku?
1990 300ce supercharged and intercooled
Bigger injectors will not do anything unless you are maxing your current ones out. Your stock injectors can easily handle 300 hp. Also you could simply up the fuel pressure a little to gain more cc of fuel. Ignition timing is probable the largest gain you can get from the stock setup.
1999 W210 E300 Turbodiesel
Former Vendor of MBWorld
1 Post
Chrysler Crossfire
We offer slightly larger injectors for the M112 motors. They are only about 20% larger, but the improved design allows for much better fuel atomization.
Tune, injectors, intake, yields about 40HP more on that motor.
The M112 has significantly smaller injectors then your motor though, so if anything I would only replace if needed to out of failure.
M104 comes with some SERIOUS heavy duty injectors and its fuel pressure is extremely high, Fuel is the LAST modification you need to do on the C36. I wouldn't be surprised if those injectors could handle 325-350HP easy. Those cars already run notoriously rich, you don't need to make them run even richer than they do. Try to open up the intake & exhaust up for more power. Also you can do a stage 2 tune for the C36 with will extract the full potential from the stock injectors, if you need more info PM us.
500E Signal Rot
