100k C36 Suspension Overhaul - What to Replace?
Old Dec 22, 2008 | 10:32 PM
onewhippedpuppy's Avatar
Plays With Cars
I'd like collective advice on my upcoming suspension rebuild. My W202 C36 AMG has 99k and obviously worn-out tie rods, I'm trying to determine what else to replace "while I'm in there". The only item with visible wear is the outer tie rods, which have torn boots. Other than slightly loose steering, it drives great and shimmy free. I'm on a budget so I can't replace everything, but I'd like advice as to what is typically worn out at 100k. My list right now:
Complete tie rod/center link assy
Idler arm bushing
Front sway bushings
Ball joints
Rear sway links
Front lower control arm rear bushing
Thinner spring pads
I also found some old threads regarding poly control arm bushings, but I can't seem to find them online. Any new sources?
Old Dec 22, 2008 | 11:22 PM
Mikegpr03's Avatar
C63
front sway for sure
Old Dec 22, 2008 | 11:50 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
get performance swaybars (eibach or HR), and get bilstein HD or sport shocks (depending if you want springs also). Also BE SURE to replace the steering damper, its only $26 and it made a world of a difference in the way the car's steering felt and yours is almost certainly probably worn out.
Old Dec 23, 2008 | 08:09 AM
Plays With Cars
Steering damper is already done. I don't have the budget right now to replace the shocks or sway bars, that will have to come later. By the way, what is a good source for performance sway bars? I don't think I've ever seen them for the C36.
Old May 4, 2009 | 05:19 PM
Affalterbacher's Avatar
C36 AMG, E46 M3 Coupe
Hi,
you can get front & rear for C36 from Eibach, perfect quality, made of aircraft quality ChromeMoly steel tubing, made in germany, perfect fit, no surprises and comes completly with all parts incl. bushings.
However you'll feel a significant change in stiffness of your vehicle, maybe more then you expect or asking for!!!
