Small oil leak - looks like coming from oil pan
Old Jan 5, 2009 | 05:58 PM
maxbhp's Avatar
My C43 has 95,000 miles now and their is a very slow leak coming onto the garge floor. Oil levels seem fine and I topped it up to be safe. When I get under the car, it looks like the oil pan is a little wet.
i am hoping it could be just a seal or manifold that is shot and worried about taking it in to a tech $$$.
BTW, anyone have a good mb tech they could recommend in So cal area?
Old Jan 5, 2009 | 06:17 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Hyevon Motors in Westminster is the only place to go!!
contact sergs99m3
Old Jan 5, 2009 | 06:26 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
Probably your front main crank seal, they give all the time. double check to see if its coming from the front of the crank. Look on the sides of the crank pulley, if you see oil be splashed around onto the block its typically front main crank seal. The stock design was really weak and they have upgraded it to a much more robust design. Its real cheap, like $30 roughly + labor. hope that helps.
Old Jan 5, 2009 | 07:34 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
+1.
i had the same exact problem on mine about a month ago.
i use G & N motors on santa monica blvd in westwood. (310) 441-1956, ask for george.
good luck.
