C 36 oil change.. ?
Old Jul 15, 2009 | 07:18 PM
redc36AMG's Avatar
1995 C 36 AMG
C 36 oil change.. ?
Hello again, well it's time to change the oil on the c 36, I wanted to do it my self since I do all my other vehicles but they're not MBs, anyways I guess I'll start with the basics where is everything at ? filter I think is on the back right side of the engine bay right ? where is the oil plug ? any tool special tools I may need ? every and all help will be greatly apreciated, any websites that I can go on ? well as always thanks for all the help.
Mario
Old Jul 20, 2009 | 12:55 AM
Z06EATER's Avatar
1997 C36AMG
wat up bro!
you need nothing special but regular tools man,
all i'm gonna tell you is good luck getting the oil filter cap off, if you tightened it really tight last time. remove that under plastic under the oil pan, your bolt size to get the oil out should be 12 i think... GET YOUR OIL FILTER FROM MERCEDES, dnt buy the cheap generics from pepboys, autozone etc...do it right, also throw a can of seafoam in the crankcase and start her up from ten then drain the oil, this will clean your internals and you'll love the performance after!
