Engine coolant temperature sensor
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
The temp sensor is located next to the thermostat housing and is held in by a clip that is easily removed with a flat blade screw driver. Make sure you have the radiator cap off when you remove the clip, you don't want any pressure in the cooling system.
