1998 BRABUS C 5.8
1. If you even still own the vehicle?
2. What has the ownership experience been like, any issues? Other than regular maintenance, I'm assuming we don't hear much because they're really so solid.
3. Any more upgrades/how have the Kmacs, LSD & KWs been holding up?
4. If you could share some more photos or videos-I love seeing these rare gems.
5. If you've tested top speed?
You’re not ignorant! I haven’t offered an update in sometime, so allow me to bring you up to speed. Yes, I still own the BRABUS C5.8. I drive my G55 Grand Edition in the winter and I drive my E55 Kleemann Stage 4 as my daily in the spring, summer and fall. I pulled the BRABUS out of storage last week and I hope to drive it occasionally on the weekends for the summer season, but I haven’t driven it even 1 mile yet. The experience has been great. I, like many of you, love the W202 and my desire for horsepower led me to the BRABUS. The BRBAUS is a remarkable example of what the W202 is capable of when you have the right team behind the build. Unfortunately, I haven’t even seen the full extent of what the vehicle can do and to be completely honest, I haven’t even pressed the vehicle a little bit since acquiring it. The BRABUS engine and various upgrades do not require anything above and beyond regular maintenance. That said, if you’re a perfectionist like me and you own an older vehicle, the preventative maintenance is always something that you address whether the vehicle needs it or not. Below are the items that I can remember at the moment:
Four seasons ago, I focused on the interior of the vehicle and I worked with a gentleman whose company specializes in interior restorations of vintage Roll Royce.
- I purchased an entire matching C43 interior set (i.e. seats, headliner, rear deck, wood trim, etc.) and took the best pieces from it to help freshen up the BRABUS.
- I had a set of the wood trim completely refinished (i.e. sanded, stained, polyurethaned, etc.) just for safe keeping.
- I had the other wood trim set wrapped in 3M 1080 Brushed Steel vinyl and installed on the vehicle.
- I had the rear deck and all pillars color matched and re-dyed to address any fading from the sun.
- I had an OEM retractable rear sun shade installed with the appropriate OEM switch and OEM shift plate.
- I had a chrome BRABUS shift knob and stainless BRABUS door lock pins installed.
- I had the best set of seats cleaned/reconditioned and installed in the vehicle.
- I had the other set completely resprayed/refinished and put them in storage for safe keeping. Countless hours went into color matching the silver, but the results are pure perfection.
- I selected the best door panels and trim pieces and had them installed as well.
- NGK plugs
- Magnacor wires
- Refinished the ceramic coated valve covers in Ferrari Red
- Valve cover gaskets
- Timing chain
- Bosch clear corners installed with new bulbs all around
- I set the BRABUS wheels off and had them refinished and re-chromed
- New Michelin Pilot Super Sports all around
- KW Variant 2 Coil-over Kit. Countless hours were spent to achieve the perfect ride height.
- Wavetrac Helical limited-slip differential
- Full trans service and trans gasket with Red Line D6 trans fluid
- Brembo brake pads and Brembo brake fluid
- KMAC front camber/caster kit
- KMAC rear camber/toe kit
- Differential mount bushings
- Drive shaft flex disc/joint kit
- Engine mounts
- Idler arm bushings
- Stabilizer/sway bar bushings
- Tie rod assemblies; left, right and center tie rods.
- Complete rear suspension control arm kit
- Front passenger side lower control arm kit
- Front driver sider lower control arm kit
- Front passenger side upper control arm kit
- Front driver side upper control arm kit
- Transmission shift linkage bushing
- Steering stabilizer
- OEM windshield replacement due to rock chips
- $4K in paintwork to address rock chips on the hood, scratches from the seat belts hitting the door jams, scuffs and scratches on the bumpers, all from the previous owner.
- Diff fluid flush since the break in period on the Wavetrac Helical limited-slip differential was completed.
- Recondition the headliner
- Refinish/recondition the steering wheel
- Full Interior/Exterior Ceramic Pro treatment (i.e. paint, leather, wheels, plastic, vinyl, glass, etc.)
- XPEL Ultimate Plus Paint Protection Film on the full front of the vehicle
Rest in peace to Bodo Buschmann!
TJMJR
TJMJR
It’s my pleasure. I’m glad that there are others that can appreciate the time, effort and money invested into keeping this W202 on the road for years to come. The level of maintenance may be considered unnecessary to some, and they are absolutely entitled to their option. I also know that there are others that do the same for their vehicles and I applaud their efforts! In my humble opinion, if you’re going to test the performance limits of any vehicle, you better be damn certain that it can absolutely handle what you’re asking of it. You don’t want to have any regrets about cutting corners when you’re traveling at 180 mph+.
TJMJR
I did purchase the vehicle in 2009. It was an exhaustive process with all of the inspections, dyno, shipping, etc. It’s been even more exhausting getting it to where it’s at today, but it’s been worth it in my opinion. I pulled the car out today for a ride around the block and it still makes me chuckle
when I hit the gas . . . just like it did the day it arrived. It’s an absolute BEAST of a W202. TJMJR
Thank you! I like the brushed steel trim, especially given the silver exterior and interior. I did have the trim along the windshield wrapped in 3M. I also have the BRUBUS door pins, but I just noticed in the photo that I haven't installed them yet.
TJMJR
Would love to know if you still have this car ... C58 BRABUS
And
If you would consider selling it ... please reach out to me on bohkltd@gmail.com
Thank you
