C36 4-speed Neutral Safety Switch Whereabouts?
.....mind as well put new shifter bushings in once I figure out where this thing is.
Make sure the connector isn't full of moisture or the wiring harness damaged.
It can be accessed with a 1/4" drive set - removing the transmission mount and letting the rear of the transmission drop a bit helps some.
