c43 Loss Of Power....Wooshing noise from engine
1999 c43 AMG
Hey all,
Recently I've noticed a considerable loss in power from my engine - approx 40% reduction. At higher rev's the classic AMG sound is lost and replaced by a high pitched whooshing sound. Any thoughts where to begin?
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
While we are more than willing to help you as much as we can ..we need more info - mileage , maintenance history etc.You could have a mass air sensor going bad....a bunch of things.Please provide as much info as you can.
BTW.....welcome!
BTW.....welcome!
1999 c43 AMG
Thanks for the quick response…greatly appreciated!
Car Info:
-128,000 miles, original engine, new transmission (30,000 miles ago)
-oil is regularly changed every 6-7,000 miles with Castrol synthetic 0W-30 euro spec
-I’ve owned the car for about a year now
Within the last week:
-Just completed some regular suspension maintenance – left front control arms (bushings and bearings), right rear control arms, and
-transmission mount
-oil cooler seal and both valve cover gaskets (oil leak)
-Spark plugs and wires
Current Symptom:
-Car did not have the reduced power (coupled with the whooshing noise) after it sat for a week in the shop, but I did notice this symptom before taking it to the shop. 3 days after driving it (20 mile drive to work) the noise started again. Not sure why this didn’t occur after sitting for a week?
I haven’t touched the mass air sensors or any other similar items since purchase. I also don’t have records of them ever being replaced by previous owners
Car Info:
-transmission mount
Current Symptom:
somewhere between 110k-120k i m at 141k now and the problem hasn't occurred. actually somebody from this forum recommended it. put half of the bottle in the gas tank, fill it up half way, put the other half in the oil tank, drove it hard till the fuel tank was about to run empty and than took it in for a oil change and everything was fine after
Car Info:
-transmission mount
Current Symptom:
Car Info:
-transmission mount
Current Symptom:
1999 c43 AMG
I'm due for an oil change shortly so I may give the seafoam a shot this weekend before I change it. I did some digging, and it seems like other people have had success with seafoam. While I'm working on the car, I'll be sure to check out the air filters.
Depending on how she runs post seafoam, I may replace the fuel filter. I will also be sure to let you guys know the outcome. Thanks for the advice!
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
sounds like vacuum leak of some kind. Make sure all the air hoses are air tight and there are no cracks or leaks of any kind. Also check gaskets such as valve cover gaskets & etc. Hope that helps.
2004 Ran SRT-10,2007 S550,2016 E400c
Any check engine light... Any noticeable missfiring? Before you go and put parts check the fuel presure.. Maybe vacuum at idle with a gage just to start getting some ideas..
Agreed, check the Valve cover gasket..... mine was bad when I got it, had loss of power.
Not so much on the fuel\air filter and injector gig. Doubt that has anything to do with it.
1999 c43 AMG
I just had the valve cover gaskets replaced recently due to a leak and that didnt seem to have any affect on it. The noise / symptom isnt really noticable untill higher rpm's (4,000).
there are two sets of valve cover gaskets, most replace the bottom one, but do not replace the upper gaskets so you may still need to do this. The upper ones are usually the ones that create vacuum leaks the most.
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
Whooshing noise
Could it be the engine fan which is turning on a permanent basis? Makes a real racket at high revs? Perhaps the fan auto coupling is not disengaging. However it would not be the cause of the great power loss you are talking about.
1999 c43 AMG
Hijack
Sorry if this is a hijack, but I need to know what are Seafoam and Redline??
1999 c43 AMG
No check engine lights or missfirings....There is a slight pinging or ticking that is noticable at certain rpm's (especially next to buildings with the windows down). I assumed this was a small muffler leak and was not related.
Fuel system cleaners..... I suggest REDLINE, I have had great experiences with it in my C43 and my Accord. Will help smooth out rough idles and restore lost performance. That being said this isn't a miracle in a bottle, it won't fix major issues. It simply gives your fuel system a good cleaning and will help remove any deposits etc.....
